Westfalia Essen 1976 400kg
  • Hello everyone
    I was glad to see that there was a community of old and new trailers
    I'm at the beginning of a redevelopment process.Westfalia essen 400 kilo From the 1970s
    And I have many questions on the subject
    Does anyone have any data on the springs?
    The original color is hardly preserved. [Light Gray] Anyone know the RAL?
    I purchased a three-cell HELLA taillights
    As it appears in most pictures with a plastic base
    Is there metal and if so where?
    attach pictures
    Thanks everyone
  • Which light do you mean? The round or rectangular one?
    There ist a Hella with metal base plate: 2SE 997 008-001
    But its only for horizontal mount and the turning signal ist in the middle.
    The one mounted on your trailer seems more like 2SE 002 578-701. I recall them with metal platte, but unfortunately they are not available any more.
    The round one doesn't really look like Hella. Some similar but only with plastic body: series 964 169 and 344 169.
    br JAU
  • Das Eingangsposting ist missverständlich. Er hat schon irgend ne Hella gekauft (welche genau? eine oder zwei?)...ich frag mich was sein Problem ist. Will er 'ne andere? Kann ja mal vorkommen. ;)
  • Hello everyone
    I am in the process of renewing 1976 westfalia essen 400 kilo
    I try to keep the originality of the parts as much as possible.
    The original rim is made of aluminum with a central axis
    . What is the maximum speed for this configuration?
    Can I change to a faster device?
    Also he was equipped with springs [probably from a local production] What alternative do you recommend
    And if so what what required?
    The wooden boards were in catastrophic condition.
    Anyone know the specification?
    best regards
    yehuda levi
    israel
  • Hi, Yehuda!
    I‘m not the biggest „Essen“ expert, but here are my 2cents:
    - What is the maximum speed for this configuration?
    Usually, the maximum speed for trailers in Germany is 80 km/h. Because these trailers were sold mainly on the german market, I think that is the speed they are designed for. You can go faster, but with tires that size I would not exceed 100 km/h.
    - Can I change to a faster device? And if so what what requ
    ired?
    No idea, sorry :o
    - Also he was equipped with springs [probably from a local production] What alternative do you recommend
    What kind of springs are installed (pic, please)? Afaik, the Essen trailers had „Cellasto“ springs, that looked like rubber. They had a yellowish color, if I remember correctly.
    - The wooden boards were in catastrophic condition
    The boards were made of plywood. It had a light, yellowish brown tint. I think they were produced by Westfalia. If You could live with a darker tone, film faced plywood is the weapon of choice. It has a dark brown hue and is very sturdy.
    Questions from Your other post:
    I saw those trailers in various colors. A wide range of greys and white, even zinc coated frames without paint. But the majority were very light grey. I think RAL 7035 (lichtgrau) is a close match to the factory color.
    The rectangular HELLA taillights are a good choice for the year. Like the right one on Your picture.
    Do You mean, You are searching for a metal base for the taillights? If so, I never had seen one. Only black plastic.
    Good luck with the restoration of Your little trailer! If you have any further questions, feel free to ask :)
    Could a mod merge Yehuda’s posts and move them to the right subforum? That would probably be useful :biggrins:
    Kann ein Mod die Beiträge von Yehuda mal zusammenführen und ins richtige Unterforum schieben? Das wäre wahrscheinlich nützlich :biggrins:
    Yehuda, wenn Du einen gut funktionierenden Online-Übersetzer brauchst, kann ich deepl.com empfehlen. Der funktioniert sehr gut und liefert die verständlichsten Ergebnisse.
    Yehuda, if you need a good online translator, I can recommend deepl.com. It works very well and delivers the most understandable results.
    Schöne Grüße aus Calenberg!
    Lars
  • Dear Lars
    Thanks for your response
    I learn more about the subject
    I'll share photos
    I use translation so there are occasional funny "translations"
    Thanks
    Yehuda
  • v8.lover
    Hat den Titel des Themas von „westfalia essen 1976“ zu „Westfalia Essen 1976 400kg“ geändert.
  • Could a mod merge Yehuda’s posts and move them to the right subforum? That would probably be useful :biggrins:
    done :)
    yehudalevi - I merged your posts about your trailer into this thread here. So everything you should need / ask for that trailer you'll (hopefully) get the answers here.
    Other than that I personally can't help unfortunately, because I only work on newer trailers...
    But good luck with the restauration!
  • On second thought...:/
    Color: Maybe the Color isn't RAL 7035. Here's an restored Essen, for sale by Kieft en Klock. I borrowed the pic from them:
    Photo Westfalia Essen
    Looks a little bit beige. Usually K en K are precise, when it comes to paint. Maybe it is RAL 1013 (Perlweiß) or RAL 1015 (Hellelfenbein).
    You can also see the original tint of the Wood.
    Springs: The cellasto springs have been a topic here numerous times before. They are easy to get, at least in Germany... Try Anhänger 24, they own this Forum :biggrins:. Search for: "Cellastofeder 400 kg".
    Sorry, I can't provide a link, but I'm sitting in front of the company computer, stealing my boss's money with private forum activities :]. It blocks shop sites. And my cell phone lies at home.
    Edit by Mod: Take this 07010 | Westfalia Cellastofeder 400 kp
    Lars
    Einmal editiert, zuletzt von Lars ()
